I haven't been able to find a howto on this.
Any info would be appreciated.
Thanks,
Kevin
Results 1 to 13 of 13
A minDVD is created just like a normal DVD but your limited to 700MB capacity of the CDR disk and very few DVD players support playback.
I have used DVD2ONE to create miniDVD. Set the ouput size to 700MB's and let it convert into a VIDEO_TS directory. Burn the CRD in UDF/ISO mode and it will play if your DVD player supports miniDVD.
MiniDVD will play in any computer,it will even play from a normal CD-ROM drive. -
I downloaded DVD2ONE and tried it. It doesn't show any titles for
me to process. What kind of source file does it need?
thanks -
I tried doing a mini-DVD in Nero by doing it as an SVCD and ignoring the warning, but I take it that's not actually a mini DVD?
So how do I do it in Nero, if Nero doesn't give me the DVD option?
Dave -
You must author as dvd and standard nero do NOT support it. You can for example use ulead movefactory to make minidvd. www.dvdrhelp.com/author#dvd
To make a minidvd from a dvd-video you can use dvd2one...but you cannot use it to make minidvds from other video sources. -
Does that mean that dvd2one will only copy an existing DVD, or that it simply won't encode to the DVD MPEG2? If I have a 720x576 (PAL that is) MPEG2 file can I put that into DVD2One to create a mini-DVD?Originally Posted by Baldrick
Dave -
Thanks for all of the info. I used Ulead DVD Movie Factory and made a
miniDVD and my Mintek 2100 won't play it. I thought it was on the list as one that reads them. Oh well.
If anyone thinks the 2100 should work please let me know. -
I have a Mintek 2110 and miniDVD doesn't work
No matter it will play 720x480 MPEG-2 3000kbps video and 384kbps 44.1khz audio fine(30min play time on 80min CD). -
What do you use to make your 720x480 3000kbps ???
Ulead Movie Factory doesn't have that option.
Thanks -
If the source is a DVD then I use DVDx,VHS I use my ATI AIW capturing with Ulead VideoStudio 6.Originally Posted by catdog6
I thought you could make a custom profile in MovieFactory because you can in VideoStudio.
Also...if you burn a raw MPEG to disk you lose PBC(<< >> ll >)
Read this guide to make XVCD with PBC:
https://www.videohelp.com/tmpgencxvcd.htm
Creating MiniDVD
By MI6 in forum Authoring (DVD)Replies: 7Last Post: 21st Nov 2008, 00:05 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 22:52 -
Finalize Sony MiniDVD on PC
By schematic2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2007, 22:55 -
Help, my PC can't read miniDVD dual-sided
By ssalim in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Oct 2007, 08:55 -
Using files from a MiniDVD Camcorder
By djc38510 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 10:57
