Hi, I have a DivX file with CBR mp3 audio with some visible bad frames and freezes in it when I watch it in media player. After the freezing there is some audio sync for maybe a minute but then it suddenly resolves itself. However when I make my KVCD using this avi the audio stays out of sync after hitting the error point. Loading the avi in VDub I tried Scan Video Stream For Errors but it found none. I also tried VDubMP3freeze to check video for freezes and it said there were none! Now I'm really at a loss as to what to do... However DivFix DOES say there are erorrs, but when I rebuild the index the resulting file is not playable in WMP (I did check on remove bad frames). Can someone please tell me a step-by-step guide as to what I should do to fix this? Thanks!
Originally Posted by wongnog
https://www.videohelp.com/forum/viewtopic.php?t=142555
Hope That Helps!!!:P
I've had problems with this too. After converting to mpeg2, the audio became out of sync. I deleted the bad frames, converted again to mpeg2, still audio sync problems. I can't understand why there are so many problems with audio sync after converting to mpeg.
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
MiniDV to DivX/XviD (w/ AutoGK): audio out of synch due to dropped frames??
By alexon in forum Video ConversionReplies: 6Last Post: 17th Dec 2009, 03:54 -
Tenders V-Dub MP3 Freeze VBR Audio and Bad Frames Guide
By tenders in forum User guidesReplies: 79Last Post: 15th Sep 2008, 21:34 -
Bad audio sync with known good xvid files
By damax452 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 16:22
