Just wondering why record now max splits the image files into 2 gigs each....I am using xp pro with ntfs...I thought it only split the files if you were using FAT 32.....and do I still need to install the ps engine if I am using ntfs?
Cheers JohnJohn
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
Mix Max Player Help
By Empty_Space in forum Newbie / General discussionsReplies: 26Last Post: 14th Mar 2012, 18:18 -
Max Mp4 player
By drrino in forum Portable VideoReplies: 1Last Post: 28th Feb 2012, 00:04 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 11:29
