  1. Any idea?
    Tested Ulead Workshop an Movie Factory but both Tools did not support AC3 in the .mp2 file
    I get the files from a dbox2 with NGrap...
  2. Huh? Ac3 and mp2 are two different audio formats. Do you have an mp2 file or an ac3 file? It sounds like you have a mp2 file that was encoded from an ac3 file. Once you re-encode its not an ac3 file any more (no more than a mp3 encoded from a wav).
    Some authoring programs only accpet 48khz PCM or ac3 data. I don't use Ulead but that could be the case. I would suggest either using the original ac3 file (which should be smaller anyway) or re-encoding your mp2 file to ac3 with BeSweet.
    Feb 2003
    Hamiton, NJ, USA
    Just FYI, the Ulead DVD Workshop demo does not support AC3 in any form. The full product will accept (and not re-encode) .mpg files with AC3 "muxed" with MPEG-2 video. TMpgEnc [Plus] will perform the multiplex operation if you can provide the .m2v and .ac3 files.
    Cheers,
    . Fred Scheifele
    . http://www.Scheif.net
