i was wonder what I am doing wrong. I decrypted a dvd with dvdDecryptor then used dvd 2 one and the files that dvd2one produced are all too big to put on a dvd now?![]()
Results 1 to 17 of 17
DVD2one defaults to a total file size of 4.36GB which leaves just 20MB to spare so some burning programs may not like this file size. The latest version of DVD2one allows you to set the output file size so try setting the file down a bit and see if that works.
how would i do that? when i open dvd2one that are no settings to lower the file size.
Well true it's the VOB files that are being re-encoded by DVD2one. If you don't see a place to set the output file size then you have an older version so go to http://www.dvd2one.com/ and download the latest version.Originally Posted by LiquidXTC
i think i am doing some thing wrong is that a way to contact u? aol AIM?
The latest version of DVD2one is V1.0.2 and on the first screen right below the file destination entry block there is a default file size of 4.460MB just change that to 4.4GB for example.
i put the VOB files into a folder called VIDEO_TS then burned that folder how come the player will not recognize the dvd on my computer drive.
did you put just the VOB files? or all the files from Dvd2One's decoding? because you still need an .ifo file, a .bup file and whatever else DVD2One createsOriginally Posted by LiquidXTC
When you ripped the DVD did you rip in the default file size of 1GB for each vob file? I've noticed that DVD2ONE produces a larger output if I use anything other than 1GB vob files.
i copyed the VIDEO_TS and it playde on my computer but didnt play on my stand alone player. is this because i didnt put in a AUDIO_TS folder as well?
Some stand alone players will play DVD-R or DVD+R media and some will do both. You can check to see what media your player will do by clicking on the DVD player link at the top of this page then do a search for the player.Originally Posted by LiquidXTC
Also if the burned media is not finalized or closed it will not play on most stand alone players. -
my stand alone player plays my dvd that i burn with dvdx copy just fine. when i burn my dvd2one discs i use ez cd careator. when i put the file ez cd it says " your project contains more than 4 GB of data. at the end of the recording disc will not be closed no more data can be added to it."when theres 13.08 megs free space it says for that disc.i dont under stand what the probelm is so if any one knows that would be great.
Yeah ECDC is borked and it does the same for me. Use RecordNow to burn your DVD media. Another great product is NeoDVD Plus which not only will burn or copy but does capture/import/edit/author as well and does it fast.Originally Posted by LiquidXTC
but do i have to put in an audio_ts file as well as a video
and do i just call the folder i burn VIDEO_TS -
All you really need is to put all the files in a folder named "VIDEO_TS" then burn that folder. You can add a AUDIO_TS folder if you want however I have burned over 200 DVD-R and never put in the AUDIO_TS folder.Originally Posted by LiquidXTC
BTW the only thing I use ECDC for is to make an exact copy of a backed up DVD. Funny thing is when doing that it doesn't have a problem with the 4GB limit.
