    Aug 2002
    England
    Simple question.
    I have 80gb Hard Drive and a CD Writer/DVD Combo.
    Obviously the Hard Drive goes on Primary Master.
    But what about the CD Writer?
    Primary Slave or Secondary Master?
    Does it make a difference?
    Cheers
    Fozzee
  2. Member Treebeard's Avatar
    Aug 2002
    I would use the Secondary master. keep HD's on the same IDE and cd/dvd drives on the other IDE.
    Mar 2002
    United States of America
    I use secondary master for my CD Writer also.
  4. I have 120GB WD HDD, TDK veloCD 321040x CD-RW, and LG DVD-ROM. Obviously, the HDD is the Primary Master. My DVD-ROM is Secondary master and DR-RW is secondary slave.
    For you, your combo drive should be Secondary Master IMHO.
    *** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
    Jul 2002
    Scotland
    I have my optical drives set on cable select - what is the difference ?
    I have had no problems with burning, ripping etc.
    dlb.
