I have several divx movies that i am trying to burn onto dvd. standard 4.7gb dvdr can fit something like 120-150 minutes of video, however i have movies longer then that. theoretically, since dvdr holds 4.7 gb, and dvd players can read vcds, is there any possible way of putting 4.7 gb worth of vcd's onto a dvdr and still have a dvd player read this? does anyone have a link for a guide for this or something?
i also have a few of the movies that are 16:9, but show up in full screen, so the picture is vertically stretched out and is very annoying. which settings do i need to plug into tmpegenc to convert the video to 16:9 with the black horisontal bars on the top and bottom? i realize that to do this, i will have to convert the video to mpeg, but i plan on doing that anyway.
thanks in advance for your replies.
Itīs all about quality. If you sacrifice quality you can fit alomost how much you want on a dvd.........
"Iīm not popular enough to be different" -
yes, but what exactly is the res/bitrate/settings/etc do i need to do this with?
and what do i burn it with so that i can have a selection of which one of the movies i want to watch? -
I canīt answer that, it depends on what sofware you are using, what source you have, what quality you want etc....yes, but what exactly is the res/bitrate/settings/etc do i need to do this with?
Why donīt you do a forum search..I have seen threads about this before.
If you want to store more(4 hours or more) on a dvd use then lower resolutions and low bitrates(vcd and svcd bitrates). The quality will then be the same as vcd,svcd,cvd. DVD supports both mpeg1 352x288/240 and mpeg2 352x576/480. You can choose those resolutions in the tmpgenc wizard.
And PLEASE also tell us what tools and settings you use now.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
