I've been using TMPGEnc for all my avi to SVCD conversions but read on here that MCE encodes at 1:1, (man what a god send) with that in mind I thought I'd try the demo out.
Sure enough it's quick, the only thing I'm unsure of is the file size, TMPGEnc allowed you to adjust your average VBR rate to suit the file size you want. I typically want a size of 915Mb.
How do I achieve this and also get the highest average bitrate possible.
MC have also a VBR option with maximum, minimun and average bitrate. i tried yesterday to encode an avi file and it ended with the desirable file size. it have also an option to split the encoded file directly, only typing how many Mbytes you want per split file.
the only cons is that it not keep aspect ratio of input file. it always encode at fullscreen, and frameserving from virtualdub to add black borders to keep the aspect, it results in a green image encoded file. -
Regarding aspect ratio, I just found out how MCE handles that.
If you have a DVD movie that has a 16:9 aspect ratio, go to "Details" --> "Advanced" and choose 16:9. Most DVD authoring programs respect this and so do DVD players.The more I learn, the more I come to realize how little it is I know. -
i have no tried a dvd movie yet with MC, but with divx files no luck. always full screen with 4:3, 16:9 and 2.21:1.
in tmpgenc i have no problems with aspect ratios, "keep aspect ratio" does the trick perfectly. tmpgenc add 2 black borders to top and bottom and voila!
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
