I have a pioneer 343 that plays VCDs and SVCDs. I got a Apex 1500 at christmas for upstairs and it seems to play VCDs just fine but has problems with SVCDS. It will play maybe half of a SVCD movie and get out of sync and just get so bad you have to eject the cd and say screw it.
How hard would it be to take a movie I already converted to SVCD to VCD or take a mpeg2 movie and convert it to VCD? Could I just use TMPG and save a mepeg2 movie to a VCD template? Im open for a easy way to do this if possible.
Thanks!
Results 1 to 10 of 10
Go ahead and try TMPG. In the project wizard choose VCD as the output. Put your original mpeg in as the source and away you go.
If you want to test your 1500, you might want to try and re-encode your original file using one of the SVCD templates in TMPG. It might be worth a shot to see if the original file is out of spec.
Good Luck.
Tivo Homer -
did you try the VCD header trick????
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
It is a way to play SVCD's on a DVD player that does not support it
In essence what your doing is creating a non standard VCD so if your player can play VCD flawlessly then (in theory) it might play a non standard VCD......look around on the guides it is very easy to do ...
Using an mpg editor (like Tmpgenc) de mux the file then mux the file as a
VCD non standard .......
Hope that helps....that way you may keep the level of quality and with out the need to re-encode...please note it may not work...but it just might be worth a shotHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Here's the header trick:Originally Posted by BuckMaster
http://www.vcdeasy.org/modules.php?name=_Guides&id=VcdTrick
Hope That Helps!!!
:P
Here's a guide for converting SVCD to VCD even though you will lose quality:
https://www.videohelp.com/mpeg2tovcd.htm
Hope That Helps!!!
:P
Your machine is probably defective. I have an apex 1500 and have never had a problem playing an SVCD.
I've never had a problem playing a SVCD with my APEX AD-1500 either.Originally Posted by zanos
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 08:35 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 23:56 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15
