I'm having a problem with IC7 that I hope someone can help with.
I've installed this app & the reghack as per mrbass and his excellent tutorial.
Following the tutorial I have no problems. Once I have entered all the details and then get to the part where I remove the audio tracks that I don't want and adjust the size of the various titles all is going OK.
It is when the app starts to do it's thing after this that the app falls down. Basically it just hangs. I have left it at this stage for 2 hours - on numerous occassions - but nothing is happening.
If I try to cancel the app nothing happens. The only way out is to reboot the machine.
I have tried removing and re-installing the app and disabling my anti-virus that runs in the background but still no joy.
Anyone got any ideas whats happening here?
I had the same problem running on WIN98ME. I concluded IC dosen't like Win98,probably needs NTFS file system to run properly.
Pinnacle AV/DV Card - problem with color
By leniwiec in forum Capturing and VCRReplies: 1Last Post: 2nd Jun 2010, 17:48 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09 -
pinnacle 11 - sound capture problem
By lhg033 in forum Capturing and VCRReplies: 3Last Post: 1st May 2008, 19:56 -
Pinnacle studio program stability problem
By SearchQuality in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2007, 20:06 -
Pinnacle DVD Problem?????
By Kmbfd558 in forum Authoring (DVD)Replies: 0Last Post: 15th Jul 2007, 08:31
