  1. I'm using an old version of Tmpgenc. I've made mpg2 files successfully for a long long time. but for some reason the default settings have changed and the last file I created could'nt be used by my authoring software because I did'nt have sequence headers before every GOP.
    I went into the settings in TMPGENC and found the output interval was set to zero. I've never had to set this before, should I just set it to "1" ? Will that give me a sequence header before every GOP?
    Thanks.
    S&M
    Aug 2001
    Dallas, Texas; U.S.A.
    SexMoron,
    ShortAnswer: Yes
    Use these settings to maintain VCD or SVCD Compatability:
    -Epi
