    Sep 2001
    I am trying to extract the audio track from a divx .avi file to a .wav file using Virtualdub. It is giving me an error saying:
    "The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format."
    When I check the file information in Virtualdub, the audio compression says: "Unknown (tag 2000)"
    Any ideas on how I can extract this audio track?
    Thanks!!
    Apr 2002
    Oskeeweewee Ontario
    It's AC3....
    Check the guides on the left, or a search will help...
  3. i find when it does that that the avi has to be decompressed
    take a look at www.data-uca.150m.com/vcdencoding.doc
    i wrote it for a mate it helped him
    also to find the decompresser look left under tools for simple encoder the decompresser come part of the download
