i had a ground loop problem with my cable and tv tuner a while back, so i was surfing the boards looking for an answer to this. the easiest way seemed to be using two 75ohm to 300ohm adapters back to back to eliminate the loop. so i went out and got them (not much, like $6 total) and plugged them in. it went great, and no more ground loop.
however, it blocks out all the lower channels (like 2-25 or so). i would like to capture shows on some of those channels, but have been unable to do so so far. are there any other solutions that would solve the ground loop issue and restore my lower channels?
Results 1 to 1 of 1
just add "salt and freshly ground black people"
By lordsmurf in forum Off topicReplies: 1Last Post: 25th Apr 2010, 11:35 -
How to filter out a ground buzz
By pdx10 in forum AudioReplies: 4Last Post: 24th Mar 2009, 10:14 -
i'm out of the loop..could someone update me?
By 91rtstealth in forum MacReplies: 6Last Post: 6th Nov 2008, 18:48 -
C# loop issue
By Darth Paris in forum ComputerReplies: 7Last Post: 23rd Oct 2007, 19:36 -
Ground Loop problem. Subwoofer hum. Will this gound isolater work on HD
By Denvers Dawgs in forum DVB / IPTVReplies: 3Last Post: 17th Jun 2007, 00:43
