I have an pioneer Ao5 i find these BulkPaq 2x Generation 4 have worked excellant 4 me up until today .. cracking open a new pack ov 25 the first 5 made some nice coastershave tryed dvd-rw and other dvds they work fine, is it a faulty batch has anybody else had this problem with these disks ?? i use diskjuggler and vob instant cd/dvd and both give problems with these disks
My work sweet, no probs @ all.
May I ask where you got them ? I need some more and no one seems to have any
the thing with bulpaq disks are that they all have different batch numbers & some have different dye types! My friend had the same bother with them on his ao5 but they work fine on the ao4 which is a great shame as these disks actually look & feel better than the older ones. I think the dye type on these disks are TDK but they may differ from batch 2 batch.
Had the same problem last week. Disks burnt well, but stuttered or stopped half way through play back.
I did note that whereas all my previous batches of green Bulkpaq had a white ring around the hub of the disk, these had a transparent ring.
I sent them back and got a full refund. Apparently it is well known that a large batch of faulty disks were introduced to the market, but not recalled by the manufacturer.
Paul -
I had the same problem..... bought 100 of them a got about 40 back Grrr...
same jitter play back....I got twenty back from one customer whos wedding I transferred from video to DVD..... lost a lot of business because of it. I'll never buy them again. -
Not trying to provoke you but for a business shouldn't you be using higher quality media and passing the cost on to the customer?Originally Posted by Wookie
datasafe classics work ok in the ao5 2 speed disk but I tend to stick to 1 speed as its sorta cheaper
I've contacted bulkpaq before regarding there crap media & well they just dont reply!! so I chose another brand of disk..
most of the expensive disks work a treat but the cheaper ones tend to be a bit crappy!!
white label work ok (princo)
datasafe & datawrite media ok (princo)
zero defex media ok (vivistar, ritek, tdk)
ritek based dvdr's are perfect
datawrite/datasafe classics ok (tdk dyd)
these all currently work fine on the ao5 for data & video
Kev! -
There is or was a problem with these discs, there was a batch that were consigned to the furnace that some bright spark decieded to put into the marketplace the key to identifing them is that the bad ones do not have the white plastic ring in the cake boxes. As someone said earlier.
I have used these disks before and after my crap 25 and apart from the crap batch that I had these are generally great media.
I have a 105 with firmware at 1.21.
TT_VTX.log generation ...
By AEN007 in forum Capturing and VCRReplies: 4Last Post: 12th Sep 2011, 02:52 -
Ipod 4th generation help?
By Pumkinhead in forum Portable VideoReplies: 1Last Post: 26th Nov 2010, 09:01 -
Next Generation Video
By sagat93 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 19:00 -
Lost Generation
By freebird73717 in forum Off topicReplies: 0Last Post: 7th Aug 2009, 10:35 -
How to avoid Generation Loss as much as possible?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 16th Sep 2008, 19:51
