I don't like the quality that TMPGEnc does for encoding sound so I want to use VirtualDub to make the sound file, but when I tried to save an MPEG that was 44 mins long it only encoded 32 mins of the sound and so when I went back to re-encode to make a new video, only half of the video had sound, and at about 32 mins into the movie it goes mute. What am I doing wrong and is there any ways to fix this or another way to convert the sound?
Thanks,
Mike.
Did you check for bad frames? Under video in Vdub use "scan video stream for errors." If there is some then save avi.
Saving in VirtualDub
By aaxpers in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2012, 12:02 -
Vegas 10: saving audio tracks to seperate .wav file
By Toastie in forum EditingReplies: 8Last Post: 6th Mar 2011, 21:50 -
Help Me For saving Watermarked Video in VirtualDUB
By J!THESH in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2010, 07:27 -
By Qrees in forum EditingReplies: 6Last Post: 5th Jul 2008, 10:06 -
VirtualDub error while saving with subtitle on
By ajumma in forum SubtitleReplies: 0Last Post: 3rd Jun 2007, 01:35
