Hi,
I recently downloaded and started using TMPGenc 2.510.
Before on version 2.58, I could set up 2 pass VBR with 2520|600 max|min and then adjust the average to be whatever file sive I wanted (about 915Mb).
Now using the new version I cannot reduce the average bitrate below 1600, meaning my file sizes are 950Mb minimum.
Anyone got any ideas???
Thanks Mark
I found the same thing you mentioned weird. Besides, after many tests with the newst versions i could NEVER see any significant improvement in performance (even they said the versions after 2.58 were optimized for P4...) therefore my advice would be to do the same i did: keep the version 2.57.41.146, it's the best build they've released so far!
Thanks for advice, don't suppose you have the install file as I deleted mine and coouldn't find it on the site
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 14:30 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
hanbrake average bitrate
By scarlac in forum Video ConversionReplies: 4Last Post: 12th May 2010, 13:35 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 18:49
