Did someone get this to work with power dvd.
i can't get the second audio to work.
i did my svcd with tmpgenc, multiplex with french and english
only getting the first audio track
thanks
Ive made SVCD's with two audio tracks, and it didn't work with PowerDVD, but it did work on my standalone. So I think PowerDVD doesn't support it. I don't know if any software supports 2 audio track SVCD's
GOOD LUCK
-+>nemo | Bejingler -
Most versions of WinDVD and SthDVD (Free) will play both audio tracks in a SVCD fine, BUT only when playing it in disk mode. For some reason, it seems to mess up when you just play the mpg in file mode, though sometimes it still works.
Some versions of PowerDVD might work, I think I might have gotten one to work before in the past. Generally, PowerDVD is not so great for SVCD playback, IMO. SthDVD is really great for being a free program. It is specifically designed for (S)VCD playback.
And of course it should always work on any hardware svcd player. -
BINGO
thanks tried another software
it did work with sasami2k
i wanted to make sure i was doing it right before burning my files
thanks alot for your help
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 19:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
