I have an mpeg2 file of my son's baseball game which I want to make into a dvd. It was a windy day and the humming noise is higher than the voice of the announcer. Is there a way for me to reduce the noise?
you must use a noise reduction process in a music editing program like cool edit, soundforge, wavelab or something else. the basic principle is that you take a sample of the sound you do not want and then tell the program to remove all similar sounds
This will work for the humming. Hum, buzz, steady hiss, etc. can be removed to some degree with these programs. But wind noise is constantly changing; you won't be very successful with this. Next time, use a windscreen.
Would like to remove or at least reduce wind sound from M2TS video
By kmw in forum AudioReplies: 5Last Post: 11th Nov 2010, 19:06 -
Cutting out the wind noise from microphone mounted on car roof
By 872156 in forum AudioReplies: 6Last Post: 14th Jun 2009, 20:50 -
removing wind noise
By Reggie6966 in forum AudioReplies: 2Last Post: 31st Aug 2008, 11:47 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 09:10 -
Simple tool for Noise Reduction, Wind, Waves, etc
By Etherel15 in forum RestorationReplies: 1Last Post: 8th Jun 2007, 02:09
