I know that mode 2 burning on CDR allows you to burn 800MB's onto a 700MB CDR. How does it work? Is it further compressing the stream or is it dropping bits to make it fit. Anybody know?
it doesnt use the crc checksum bits .. so no error correction .. so the space error correction normally uses is used by data instead .. ok for movies and such .. not for programs or critical data..
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
2-pass mode - How does it work?
By Gew in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2010, 19:35 -
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 05:12 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
HELP! DVD Burning VOB files doesnt work
By liam0114 in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2007, 17:35
