I have made backups of DVD-5 disks perfectly with DVDdecrypter.
I am not trying to learn how to do a DVD-9 disk i dont mind stripping of extras and stuff. SO i am going to use DVDdecrypter and dvd2one. However i have a question.
All the guides say rip just the main movie VOB files. HOw do you tell which files i need are they standard accross all disks or do you just take the biggest and iff so how many
please help
thanks
Steve
LLAP-Goch... the secret Welsh ART of SELFDEFENCE that requires no INTELLIGENCE, STRENGTH or PHYSICAL courage
---Monty Pythons Flying Circus -
DVDdecrypter will automatically select the main movie files you'll need so you don't have to worry about that
The main movie is usually the biggest files, although DVD Decrypter selects the main movie for you automatically so all you have to do is select Decript.
Hope that helps.
Barry
God's in his heaven... All's right with the world!
Robert Browning (1812 - 1889) -
Thanks. That is great.
SteveLLAP-Goch... the secret Welsh ART of SELFDEFENCE that requires no INTELLIGENCE, STRENGTH or PHYSICAL courage
I do have one more question.
i know doiing it this way will strip the menu etc but will keep the subtitles. and audio streams.
will it keep the chapter points as well?
thanks
Thanks that is great i will give it a go tonight
If you use a program called make-it-easy and ifoedit you can keep the menus while using DVD2ONE.
I have done stargate using make-it-easy to keep the menu because it only takes up 40MB and won't affect the quality much.
You can get make-it-easy and ifoedit here:
http://www.doom9.org/Soft21/Vobtools/
Hope this helps.
Barry
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
