I want to use bbmpeg v1.24 to multiplex mpeg file without encoding .Can i do that?
what is your source a/v files that you want to mux?? default BBmpeg only takes mpeg-1 & mpeg-2 video...but takes just about all forms of audio...need a little more info
Now i want to multiplex a mpeg-1 file(audio+video)
Can bbmpeg multiplex mpeg file without demultiplex before?
And now why i push "start encoding" it encode instantly but i want to setting before encode -
No you have to demux in another program first, just use TMPGenc.
Follow the guide that Truman posted it explains EVERYTHING. Obviously you'll need to select vcd instead of svcd but other than that the guide is right.
Best program to use to encode subtitled vid
By enrell in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2012, 13:58 -
what program should i use to re encode?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2009, 17:36 -
Hi, need a program to batch multiplex.
By mmdmmd in forum AudioReplies: 2Last Post: 18th Oct 2008, 13:50 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 15:57 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 22:32
