Results 1 to 9 of 9
    ontario ,canada
    I am using an ATI all in wonder to capture mpeg2,but is there a sound card that will capture and encode ac3 dolby digital.I have a soundblaster 5.1 platinum,but it won't encode ac3.The all in wonder accepts stereo input for recording.
    I don't know if there is anything out there that will do this,so i thought i would ask all the afficionadoes out there if they have any experience with this.
    thanks again.
    bmiller,ont.canada
    Jun 2001
    Surface-of-the-Sun (AZ)
    If you're using an ATI to capture... you won't be able to afford AC3 capture hardware. It's professional level and expensive. Typical AC3 users re-encode the audio into AC3 in software. Unfortunately, if you capture in mpeg audio you'll loose some audio quality when you decompress to wav and then recompress to AC3, but it should be minimal.
    ontario ,canada
    I had an idea this wouldn't be easy or cheap.I just thought if i could record tv programs or movies that had dd 5.1,i would look at upgrading my hardware and software.I'll wait until the right equipment comes along.
    bmiller,ont.canada
    Jun 2001
    If it's already encoded in DD 5.1 it there may be other hardware for it (since it wouldn't need to encode)... I really don't know anything about that since I've never had digital cable or satellite. My comment was in reference to hardware that can encode an analog signal into DD in realtime.
  5. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Cheapest AC 3 card
    http://www.minnetonkaaudio.com/
  6. That site does not appear to offer any hardware.
    A "bit-accurate" soundcard is apparently required, Digi-96 reported to work, $450.00 or so. This capability should be appearing on consumer-priced (under $100) fairly soon.
  7. Actually, there are a number of AC3 encoding solutions available now. Sonic Foundry's video editor Vegas 4 will encode ac3 files and SoFo's DVD Architect will burn it to DVD. Ulead also has a new ac3 encoder just released. I've only used the SoFo software..it works OK.
    MOBO: ASUS P4P800 Deluxe
    CPU: 3 GHz P4
    OS: Win 2k SP2
    Audio: ECHO Mona
    BSCVideo Card: ATi Radeon 9800 Pro
    Video Capture: IEEE-1394 DV
    HSF: Volcano 5
    HDD: WD 1200JB
    Video HD: WD1000BB
    CD-RW: Sony
    DVD-R: Pioneer A03
  8. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Thanks Nelson I stand corrected...but I see one of thier products even supports the CREATIVE AUDIGY 2 to make Dolby AC3 5.1 audio
    maybe with our 'all in wonder's doing the video
    also they support a wide variety of regular audio cards (layla multichannel
    & others) to do DVD audio
    and make a plug in for premiere to create ac3 for 279.00
    (SurCode Dolby V-Plug PC Premiere Host Stereo Dolby digital AC-3 encoder plug-in for Adobe Premiere.)
    ps i don't work for them
  9. CREATING an AC-3 file is one thing, CAPTURING true AC-3 is another. Creating it from a Stereo file will not yield true Surround Sound, but only a reasonable imitation. Capturing the real thing, in real time, is the goal.
