Basically I'm a newcomer to the vcd/svcd field and need some help if I have an avi or xvid I extract the sound using virtual dub to a wav, I then use tmpg to convert it to svcd if its 25fps I leave it at that setting (pal), if it's 23 fps then I use the 29fps ntsc film setting to convert to svcd usually I have no problem doing this but on my logix dvd player the sound breaks up every 10 seconds or so, if I try the same disc in my pacific I bought from Asda I get no problems, anybody out there shed a bit of light on this for me so I can get the svcds to work on both, also if I'm doing anything wrong!
Any help would be much appreciated.![]()
Results 1 to 1 of 1
Playing Multiple DVD Players on a PC?
By Tchail in forum Software PlayingReplies: 9Last Post: 28th Dec 2011, 13:59 -
Proshow DVDs not playing back on Blue Ray Players
By papadish in forum Newbie / General discussionsReplies: 0Last Post: 9th Oct 2009, 10:33 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21 -
Trouble Playing a DVD in software players
By AfroPuff in forum Software PlayingReplies: 5Last Post: 26th Oct 2008, 19:00 -
Data playing dvd players?
By capman21 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Jun 2007, 21:08
