I am having audio sync problems with longer videos recorded to DVD. This has occurred with several different programs (Studio 8, MyDVD 4,..). I have read some posts about cheap sound cards possibly causing this problem. I have a SoundBlaster Live Value sound card and I am considering upgrading to something from Turltle Beach.
Has anyone had any experiences with sync improvement through a sound card upgrade??
I don't think a new sound card will help - I have a Soundblaster Audigy 2 and used to get synch problems (with Ulead MF) until I changed the program I was encoding DVD with (to SpruceUp). No more problems.
Regards,
Rob -
It won't help.
There are 3 reasons for those problems: Conflicts on the hardware, Bad Software setup, or wrong drivers/ bad drivers setup.
There is also a 4th reason, already mentioned: Bad software for capture, or third party sofware not compatible with the hardware you have.
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 15:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 03:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 01:23 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 07:35
