Hey.....
I've been using Kazaa Lite (since I've read about it not having the
ads and stuff like that, and it's been working ok). Now it says that I
have to download Kazaa 2.1.
Is this the next version of Lite, or is this just the next version overall?
I'm just afraid that it will now have the ads and spy-stuff.
Thanks.
Results 1 to 12 of 12
thanks.
So does the normal kazaa 2.1 have spyware?
I downloaded the Kazaa lite 2.1, and all I get is "more sources needed"
or "connecting", and nothing is downloading. My previous version
worked fine. Am I missing something?
Thanks. -
Standard Kazaa is loaded with spyware, which it tends to leave installed on your system even when you uninstall Kazaa. It's also got all those obnoxious banner ads and pop-up windows.
crap-ola
I'm still getting nothing with K-Lite. I just get that "more sources
needed" and stuff like that. Is it possible I've been blocked? -
use speed up and fast track accelerator to auto-find more sources while downloading.
is that a common practice to use those extra programs?
I'm just wondering if Kazaa was working fine, and now k-lite won't
work....I'm wondering if I'm being blocked (at work) from
doing this. Although....I am supposedly connected. -
ahhh, I just read http://securityresponse.symantec.com/avcenter/venc/data/w32.kwbot.c.worm.html, so I'm wondering if we are now being blocked
hey.....does anyone know how to check for and delete spyware?
(programs to use, files to look for, that type of thing....)
My pc has been running slow lately, and I'm wondering if I've
got some annoying spyware somewhere, but don't know what/where
to look for it.
(I realize there are other reasons for it to run slowly, but was just curious
if this could be one of them.) -
Use ad-aware to find the spywares and delete them. Its a free software and simple to use.
use AutoSearchMore its way better and dosent stop till you tell it to.Originally Posted by cpgoose
Want to use K-Lite? - DON'T DO IT!
By jeanpave in forum Software PlayingReplies: 45Last Post: 15th Nov 2010, 23:04 -
New Lite-on drive being recognized as old lite-on drive
By tlrbjc in forum DVD & Blu-ray WritersReplies: 2Last Post: 23rd Jun 2010, 09:21 -
K-Lite Codec for mac
By pixel zombie in forum MacReplies: 3Last Post: 9th Jun 2009, 04:25 -
Has anyone used Lite-on EZ-Dub
By Ronny G in forum DVD & Blu-ray WritersReplies: 11Last Post: 1st Feb 2008, 02:34 -
nintendo ds lite
By Mr anderson in forum Off topicReplies: 5Last Post: 19th Sep 2007, 02:02
