Hello everybody!
With my new satellite recording card, I "saved" an episode of a series I like.
So, I have this big MPEG2 file that I want to convert with TMPGEnc in a DVD compliant file, in order to author it and burn it on a DVD-R.
Problem is, if I try to convert the file with TMPGEnc, the resulting file, even though it is DVD compliant, and even though the video is ok, has _VERY_ bad audio.
Anybody knows why TMPGEnc behaves like this?
Then I tried this way:
- Extract the audio with DVD2AVI (.mpa file)
- Convert the .mpa audio file in a .wav file (with WinAMP)
- Use the .d2v as video source and the .wav as audio source forTMPGEnc
The resulting file has perfect audio (and obviously, video).
Problem is, sometimes the audio extracted with DVD2AVI is slightly delayed. How can I sync it?
Thanks for any help.
Bye,
Massi.
Its quite possible that the audio on the satellite is not DVD standard 48Khz audio. Therfore TmpGenc will convert it to 48Khz whne you select a DVD compliant format. It is a well accepted fact that TmpGenc's sample rate converter is not the best in the world and even the author acknowledges this by providing the facility to use external tools for this purpose (and for mp2 audio encoding). I suggest you get hold of ssrce.exe and set it up in TmpGenc as the external sample rate convereter. You could also get toolame as the mp2 audio encoder. It should help.
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
bad file names on audio book cd
By NetPhantom in forum AudioReplies: 0Last Post: 27th May 2010, 23:50 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
TMPGEnc - bad frame problem
By psyklax in forum Video ConversionReplies: 5Last Post: 30th Jun 2007, 22:44 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 04:33
