Hi all,
this is my first time I post on this forum. I hope some of you can help me.
I'm facing a problem with my new (two month old) Grundig GDP 3200 Livance.
I made some SVCD's from my old HI-8 video. Initially there was no problems. I read the SVDC's very well. Anyway, since a certain date I'm not able to read the SVCD's menu. As I insert the cd the player recognize the format but it seems to hang after reading the menu. The infrared control doesn't work at all. Anyway I can read the track if I select it directly before the player read the menu. I think it could be a software problem but I don't know how to solve it. Does anyone have some ideas ???
Thanks in advance
Regards
HB
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 11:38 -
Is PC2-3200 the same as PC3200 RAM?
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 7th Feb 2010, 10:33 -
DVB-S TT-budget s2-3200
By mb508 in forum DVB / IPTVReplies: 2Last Post: 13th Jun 2008, 06:10 -
Grundig gdp 1750 region hack
By matje06 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Jan 2008, 16:02 -
DVD Shrink Pause Issue - Problem Resolved with v2.5.3200
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Sep 2007, 03:58
