I try with this link http://www.coyote01.freeserve.co.uk/menu_creation.htm
But i don't understand my bmp file must to convert to mpg file? So when i drag bmp file to window it not show picture like in that link show
Please help me!
Results 1 to 9 of 9
You do not need to convert it to MPEG - just drag your bitmap file down and use as MENU page. Then add your selection items.
But you must create the Image exactly as you will want it to appear. WINONCD will only use what you give it. -
to:tommo
i use winoncd v3.7 power edition
first i select vcd 2.0 then select mpeg file and drag bmp file ,right? and how i can add selection items, i don't see any menu to do this
to:likkletree
There is a guide to the left, on this in authoring.
This guide is links that i had tried already. -
Maybe menu creation is only available in WinOnCD 3.8 Power Edition? I know the guide mentions 3.7, but I never saw any menu options when I was using it...
Tango2K.
The guide you are referring to is on my site. You must have 3.7 or 3.8 Power Edition, and you need to select the EXTENDED Editor to make a menu driven VCD. If it does not have the option of Extended editor, you do not have the Power Edition. -
TOMMO
I select EXTEND EDitor already and I follow your site
When i click RECORD Button ,it show error "Problem with building disc"
WHy? My mpeg file is in standard vcd and bmp file has frame size equal mpeg file
tango2k,
i have no idea why this is. Are you sure the size of the file you are trying to burn meets the capacity of the disk?
Perhaps, reduce the actual size of your BMP to 352 x 288 or as close as possible.
Sorry - but I have not got a clue why you are getting that message. -
Thank you TOMMO
I think problem with My winoncd
becaz I just only burn mpeg file(10MByte) not include menu
It still show "error while buiding disc"
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 07:02 -
How to make a new Menu?
By chicodesouza in forum Authoring (DVD)Replies: 2Last Post: 22nd Dec 2008, 20:13 -
How do I make a menu?
By jbigfoot in forum Authoring (DVD)Replies: 3Last Post: 27th Feb 2008, 01:31 -
need to make a menu
By m-man in forum Authoring (DVD)Replies: 2Last Post: 5th May 2007, 05:19
