Hi Folks,
I am planning on buying the ADVC100. But I understand that I also need a firewire card. Please suggest which one I should go in for. I need it to work with Virtual Dub and provide a capture frame size of 288X712
Regards
jinu
Firewire cards don't vary much these days. They only transfer data between external devices and your PC, so just buy the cheapest one you can find and it should be fine.
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
