this is srazy. ]
I hav a old 560hz computer and was using a pinnical card with xp drivers and the program noedvd it captured analog in mpg2 . then i used tmpgen to make svcd without a problem and burnt with nero
Now I upgraded to a faster computer , using the same setup
and now tmpgen wont except the mpg files. and in nero burn program it turns the files upside down when they are dragged over to set up for the conversion.
????????????????? this is bloody crazy
No, TMPGEnc can't read MPEG2. Install PowerDVD (trial if you haven't got full ver), and TMPGEnc will now use PowerDVDs MPEG2 decoder.
As for Nero - Don't use it for anything besides burning the stuff to CD/DVD!
/Mats -
thanks for that ..\
so what would you suggest as a good burning program for this project -
Just get this program and it will do it all (capture,import, edit,author,burn).Originally Posted by nonex1
http://www.mediostream.com/products/neodvdplus/index.html -
Like I said, Nero is fine for burning. The lineso what would you suggest as a good burning program for this projectmade me blieve you try to use Nero for more than burning; Sounds like you try to use it for both encoding and authoring, as well as burning?and in nero burn program it turns the files upside down when they are dragged over to set up for the conversion
The tools I use are: TMPGEnc/Main Concept for encoding. VCDEasy for authoring. Nero for burning. (A lie - I use VCDEasy for burning too, as my CD writer is supported by VCDEasy. Not all systems are, so if Nero works fine for you, just use VCDEasy to author, then Nero to burn.)
/Mats
upside down video in netmeeting
By ahidayat in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2020, 04:41 -
Image is upside down/vertically flipped after conversion
By ibzomie in forum Newbie / General discussionsReplies: 13Last Post: 23rd Dec 2008, 17:33 -
Vegas 8.0 - ITS UPSIDE DOWN!
By 1320Video in forum EditingReplies: 7Last Post: 17th May 2008, 13:35 -
My video is upside down
By Baldrick in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2007, 11:02 -
Build 2.5.3200 - Successful AVI-conversion - Upside down image..
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 4th Oct 2007, 17:58
