Hi everyone. What's a good tool to add effects and cut and join AVI files from a DV capture? I tried using MS Movie Maker, but the AVI it produced couldn't be processed by CCE.![]()
I'm trying to find an easy way to get my movies off my digital camera and onto a dvd-r.
Thanks in advance for all your help.![]()
I use Avid Xpress DV. If you're a student you can get it for about $500. (Much more if you are not.) The nice thing is that you can output your project as a small Quicktime reference file and encode it with CCE. Which helps save space since you don't have to make a new, very large file wth all the video combined. Another option is Adobe Premiere which I believe can do the same. You can do all sorts of effects in both programs.
Avid is also coming out with a stripped down, free, downloadable version of Xpress DV. However, I do not believe it is avaliable yet.
http://www.avid.com/forms/info.asp?iTrackingID=7682 -
I think you can get premiere for 200 if ur a student.
Alternatly, my friend told me i can get that stuff on E-bay if i don't mind it not being new. -
Thanks for the suggestions. I did find out that I could get CCE to recognize the AVI file if I ran the conversion utility from a type-1 DV format to a type-2 DV format. So, it looks like I might be able to use MS Movie maker after all... Free is better than a few hundred bucks..
Importing h.264 mp4 files into After Effects bug?
By Flynn in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2012, 09:17 -
Problem with adding transition effects to HDV footage in Vegas 9 Pro
By btodorov in forum EditingReplies: 4Last Post: 24th Aug 2009, 14:46 -
Recording music,editing,adding sound effects ect...
By f-zer0 in forum Off topicReplies: 6Last Post: 20th May 2008, 07:44 -
Adding special effects like countdown etc (National Geographic)
By chico34 in forum EditingReplies: 0Last Post: 15th Feb 2008, 19:00 -
problem using youtube avi files in adobe after effects 7
By method in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 23:26
