  1. i have my dvd player hooked up through composite cables to my vcr, and from my vcr i have composite cables hooked up to my tv. the problem i am encountering is that i dont have enough composite jacks to hookup my playstation or the tv out from my video card.
    is there a device that will let me hook up like 6 devices and switch between devices (with a remote control preferably =).. and no, i'm not talking about buying a home theatre system so i can hook them all up to. its costs too much. i just want a device that will let me hook up a buncha composite devices in to it.
    thanks for any help
    p.s.- baldrick, i dont know if this is the right forum to post in. its the closet one i could find. if this isnt the appropriate forum to post in, please move it to the correct one.
  2. You can find 4 inputs with remote (Sima svs-4 S-Video + composite for $120, or a 4 input composite only with remote for $40) or so, but if you want more inputs I only know of a JVC 7 input switcher, but it's $400. You might find some passive switchers, but they will not have any remote control.
  3. i'll probably go with the sima 4 input composite one for $40. seeing as how i only have 4 devices. dvd, vcr, tvout, & psx. and if i need to plug something else in, i can just hook it up through the composite jacks on the vcr.
    thanks for your help skittelsen
  4. The 4 input composite switcher can be found someplace on this web site, http://www.allelectronics.com (It's not a Sima)
