Hi...I am trying to use forty-two to decode to DVD... I select the bitrate I want (4000) click start and all I get is "encoding video.....4000kbps,vbr of" and 0 frames it has been over an hour....what am I doing wrong ?
I figured it out.....I had installed version 1 and after throwing away all 42 pieces and re installing 1.5 then restarting the computer it now works but stops and ejects the DVD before making an Iso file ?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
