I have joined about 10 14MB MPEG 1 files with Easy Video Joiner into a 140MB output file. Unfortunately I deleted the source files before checking the output file. I discovered that I could only play the first joined segment. I loaded it into various video editing programs and they all only recognize the first segment. I checked the source files to make sure that they have the same profiles before joining them. What have I done wrong here? Is there a way I can recover the other joined segments.
Many thanks puertorican138. It worked. I also found out that burning it on VCD with Nero allows me to view the entire mpeg clip.
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Joined avi file conversion problem
By siberian50 in forum MacReplies: 12Last Post: 26th May 2007, 19:04 -
Revised Question: Problem playing joined file on windows media player
By Johnny_Blaze in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 12:25 -
Problem Viewing joined hjsplit .avi file in Windows Media Player
By Johnny_Blaze in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2007, 16:22 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
