VirualDub splits the big file into to files that aren't video associated. Nero will not burn them for a VCD. What I think I have to do is make those files Video files. How do I do this, or do I do something different?
You should use TMPGEnc to convert them to VCD so Nero will accept them.
:P
Do I use TMPGEnc before I use VirtualDub or after? And what is warez and what's the big deal?
I'm not sure why vdub would be splitting your file into two unassociated files, but as for using TMPGEnc, you would use this AFTER Vdub as it creates the final MPEG that goes into your authoring app (such as VCDEasy). If you use vdub after TMPGEnc, vdub will convert your MPEG (assuming MPEG-1 and not MPEG-2, which vdbu doesn't understand) back to an AVI...Definitely NOT what you want when creating a VCD or DVD.
Hope That Explains It All!!!:P
Vegas 8.0 splits footage into multiple files!
By PapaDmitry in forum EditingReplies: 2Last Post: 4th Oct 2010, 17:33 -
WinDV splits files
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 24th Jun 2008, 01:03 -
Searching program for multiple cuts/splits in Mpeg-files
By tomk in forum EditingReplies: 1Last Post: 5th May 2008, 03:48 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
