hi,
i downloaded an SVCD proper repack of a movie, and i mounted it with daemon tools to check if it would work, and it played fine in PowerDVD, however, once i burnt the cd (both at 4x and 24x) it would not play in PowerDVD nor a standalone dvd player.
i burnt the bin/cue in Nero 5.5.9.10
any ideas?
sorry i didnt know where to put this one, so i threw it in newbie
i cant use nero,so i dont know the settings.
try extracting the mpeg file from the bin/cue with http://www.vcdgear.com/download.html then burn it. -
Nero is able to burn cd-images of type cue/bin (don't burn the cue/bin as a 'PC CD-Rom' !!). Procedure : Open the cue-file as new project, or command 'Burn image' and open the cue-file (instead of a nrg-file).
If you followed the right procedure, then possible the image you downloaded is corrupt (do the download again) or isn't a SVCD at all!
In this case, load the cue/bin via DAEMON-tools; copy the MPeG out of it; then use SVCD-authoring tools like VCDwizard (Nero could be suiteble too) and (re-)create a propper SVCD. Then burn to cd (or rewritable, so you can test it first).
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
