HI!
ARE THERE ANY SINGLE SOFTWARE OR ANY SIMPLE WAY TO COPY DVD-9 TO DVD-5? OR TO REMOVE UNWANTED CHAPTER FROM A DVD-9 TO FIT DVD-5? READY TO SACRIFY ORIGINAL MENU ETC...
PLS HELP
kill the caps thatmeans u r shoutingtry looking roundthe forum for sumit called dvd2one 8)
There are lots of software.
Rip the movie to your harddisk with "DVD Decrypter" or the ripper of your choice, then use one of the following softwares:
DVD2ONE - Just copies the movie, you can strip audio and subtitles to increase quality (Very fast with good quality).
DVDXCOPY - Splits 1 DVD9 to 2 DVD5s while retaining everything from original (Fast while retaining original quality).
InstantCopy - Copies 1 DVD9 to 1 DVD5 while keeping what ever you like (Slow with good quality)
DVD2DVDR - Haven't tried it but I hear it's good.
There are lots more but these are the most popular.
My favorite is DVD2ONE because i'm only interested in copying the movie with the good quality at fast speeds.
Hope this helps.
BarryGod's in his heaven... All's right with the world!
Robert Browning (1812 - 1889) -
Hi
Thank you for your help regarding DVD2ONE.
I try to rip with DVD Decrypter on one directory. after I stard DVD2ONE and I can't set anything, the software just ask me Source: where I ripped the movie and destination: where the new compressed file should be and the next screen showed title 1 chapter 20 and next audio ac3 2ch and finally start....nothing to set????
after it give to me as 2 set of .ifo
vts_01_01.ifo with all the vts_01_1.vob to 4 and another set of vts_03_0.ifo with all the vts_3.1 to 4.vob what it means???
No compressed? 2 disks?
Pls help!
Alain -
Ok, this is how I do it.
I made a empty folder called DVD, then I have another one called DVDFINISHED, inside the DVDFINISHED folder I have another folder called VIDEO_TS (this has to be exactly the same as shown).
I now go into dvd decrypter, I select the movie itself (which it does automatically) and rip in IFO mode (top of the window under mode).
Send the dvd files to the DVD folder. When thats done open up DVD2ONE. Your source folder should be set to DVD, and the destination should be DVDFINISHED/VIDEO_TS This way everything will be put in the VIDEO_TS folder. Once its done, thats it!! I use NEO DVD to burn, just select the DVDFINISHED folder and away you go.The light at the end of the tunnel, is some git with a torch making me go on living......
2009 DVD Copy Software
By hardy in forum DVD RippingReplies: 23Last Post: 1st Jul 2009, 11:35 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Recommendations for dvd-to-zune software? -Corel dvd copy does the trick!
By yoda313 in forum Portable VideoReplies: 7Last Post: 17th Sep 2008, 00:13
