  1. I have been trying to keep original menus only and i have succeded on a few tries. i've been able to do deep blue sea and falling down. i tried xmen and u571 but no luck. i did every step for every movie the same way. my question is do i there something or a vob i must have on certain movies? I believe a read somewhere where the fbi warning needs to be included. any help would be appriciated, thanx
  2. Hi mate,
    You will have to keep the fbi warnings to keep the menu. There is a way i think but i leave them in because too much trouble.
    I put movie files in a folder on there own, use dvd2one with makeit easy and put the shrunk vobs back after. update and burn
    Aug 2001
    Västerås, Sweden
    just open VIDEO_TS.IFO in ifedit. mark the ID you want not to be played and click delete plaback.
    *EDIT: you should be able to prewiev an item by dubbleclicking on it.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
    Jan 2003
    California
    As far as the original menu is concerned, this is what works for me...
    1. Extract entire DVD using DVD Decrypter or SmartRipper
    2. Open IFOEDIT and click 'Open' to open the "video_ts" ifo file.
    3. Click DVD Play in IFOEDIT.
    4. Play the DVD using IFOEDIT's player, manuevering through the menu to the main movie only (don't go to the extras!)
    5. Click 'Exit' to exit back to the main IFOEDIT program.
    6. Upon exit, you'll get a message from IFOEDIT stating which Title Sets you just viewed. Make a note of them!
    7. Once you're back in the main IFOEDIT program, look in the lower half of the program to match the title sets you just viewed to the VTS sets they are actually contained in.
    8. Close IFOEDIT, open the folder of the extracted DVD.
    9. Create a new folder. In that new folder copy the entire VTS sets (vobs, bups, and ifos!) that IFOEDIT said you watched when playing the DVD from the originally extracted folder to the newly created folder. Also, copy the "video_ts.ifo, video_ts.vob, and video_ts.ifo files to the new folder.
    10. Verify by opening the "video_ts.ifo" in your newly created folder in IFOEDIT again. Click DVD Play and you should be able to navigate the menu to the main movie.
    Hope this helps!
    -LF
