I am trying to write VCDs to a dvd using moviefactory 2, according to the guide it should not need to convert the video if it is in vcd format, yet no matter what settings I use it allways converts the video. I check it is correct i.e PAl/NTSC and they are all files converted to VCD using TMPGenc. Any help Appreciated
Roy
there are a few threads about this going on around here right now
I've participated in a couple, one is at the following:
https://www.videohelp.com/forum/viewtopic.php?t=145007
you may actually not be re-encoding the video, just the audio if your clips are VCD. you must have 48000hz audio and VCD audio is 44000hz. You also need to create a new disc template for doing this. It's simple and easy....the pop-up box in the lower left corner of MF 2's screen. You also must check the box that says : "do not convert compliant mpg"
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
