  1. Does anyone know where to get DVD-9 media from?
  2. Nowhere on planet earth! ie doesn't exist! Unless our talking double sided 9.4gb media.. that's it.. Use your favourite search tool for that.. you'll find it!
  3. You should be in the media section.
    You can't get them and even is you could you could NOT write to them.
    Jun 2001
    Surface-of-the-Sun (AZ)
    Read about DVD and DVD-9 here, or search the forum
    https://www.videohelp.com/dvd
  5. Moved to Media.
    While there are no dual layer single sided DVDRs there are double sided single layer DVDRs at most of the online outlets.
    Panasonic DMR-ES45VS, keep those discs a burnin'
