  1. Hi all,
    How can I create region free DVD with two systems (PAL and NTSC) on same side with auto system select depend of DVD player system?
  2. Member DJRumpy's Avatar
    Dallas, Texas
    I wonder if they could be treated as multi-angle?
    You could also just try embedding the two video streams in your MPEG, and setup a menu item that points to one or the other. I don't know if they authoring programs would choke on it though, with comliance errors.
    Impossible to see the future is. The Dark Side clouds everything...
  3. I won't say it can't be done, but I have tried quite a few DVD authoring programs and every one requires you to select PAL or NTSC. None of them would allow both formats on a single disk, sorry.
  4. Member DJRumpy's Avatar
    Dallas, Texas
    Hmm..What about playing with the header to make it appear as one standard or the other?
  5. Originally Posted by DJRumpy
    Hmm, a possibility. I think DVDpatcher will do this.
    EDIT--
    But the different frame rates could cause some interesting effects!
  6. Member DJRumpy's Avatar
    Dallas, Texas
    :P Agreed. Maybe a compromise of VCD (FILM), and PAL, since it's only 1 fps (give or take) difference. I don't know how a player would react, if the header said one thing for framefrate, but the mpeg was something else. I'm amazed that the header trick works at all. I'd be interested in the results.
