is there another program besides tmpgenc that can convert dv2 to svcd beause everytime i try to convert a dv2 file with tmpgenc, my computer restarts around halfway of converting the file. i am running windows xp
Jason
First, be sure you are able to open the DV-video.
For a list and comparisation of the different kind of encoders, see here.
While I also capture in DV (and so have DV to encode to MPeG), I still must claim that TMPGenc delivers very good results. I takes time, but it's worth it.
Your problem also could be due inproper configuration of your system. Some windows-systems (w2k, wXP) do have trouble to get 'awake' when after a while the 'auto-sleep' goes into action (this is, when nothing happens with the mouse and keybourd) while VGA and Harddisk-action mostly seems to be ignored as being 'action'. Disable this option (in desktop-properties), so the system stays 'alive' forever... But it also could be being some other problem.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
DV1 versus DV2
By SCDVD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 23rd Feb 2009, 04:18 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
