I have a decent PC with 1.6 and 512MB of Ram and 20GB free on my hard drive. This IBM laptop is really a decent machine.
My problem is that no matter which encoder I use, it seems to take forever to translate a 30 min movie. The Nero seems to take about 1.5hour. The adobe mpeg seems to take 2 hours and the DVDit PE seems to take about 1.5 hours.
I am converting from AVI to MPEG2 for DVD burning.
Is there any software out there that does not take so long
You often sacrifice picture quality for speed, but the mainconcept encoder does a good job, as does cinemacraft and both are fairly quick. Try ligos also.
Whats the fastest video encoder?
By groggit in forum Video ConversionReplies: 25Last Post: 14th May 2013, 12:14 -
which is the fastest encoder no matter output format
By gyzel01 in forum Video ConversionReplies: 30Last Post: 17th Nov 2011, 05:20 -
Most stable, fastest and easy encoder for Windows 7 64 Bit
By pectin232 in forum Video ConversionReplies: 2Last Post: 30th Nov 2010, 07:07 -
Whats the fastest FLV encoder?
By last_registered_user in forum Video ConversionReplies: 0Last Post: 9th Sep 2009, 23:17 -
Fastest but good quality mpeg-2 encoder
By cd090580 in forum Video ConversionReplies: 12Last Post: 23rd Jun 2007, 12:42
