I have had a look around the forum but had no luck so thought i best post my prob.
I have used DVD WS to make afew small menus and stuff beforeand all have burnt fine, until now. The project im currently working on will not burn, and when i say i can't burn it i mean the Make Disk icon is not high lighted so there is no way i can make an image on the HD or burn to DVD.
At the mo im really gutted as i have spent 3 weeks designing custem images and sounds to use. Can anyone help. The current project i have has about 15 or so menus......... could that be the prob??. I started a dummy project just to see if i had a problem with the program,poped in afew menus and low and behold the Make disk button WAS highlighted. It just seems that for some reason the program doesn't like my project. All menus are linked **i have Quad checked that**.
I Really hope somone out there can help
Thanks in advance peeps, ill keep my fingers crossed![]()
I think i know what the problem is but still don't know how to solve it.
I created the menu on my laptop, this doesn't have a DVDR Drive init. When i opened the project from my main pc *i also copied the file over to the other pc before opening the project*. It will open fine and all file links are ok, but i cant burn it. I think this is because the project still thinks it's on the laptop thus it can't burn it. I had a play and found that any projects i start on the laptop and try to burn it will not work. If the projects are started on the PC they arfe ok.
I find it hard to belive that this progrmas costs so much and has such a bug, why is there not a way to just create the dvd files on your HD???? then i could burn them with Nero. All i can say is im GUTTED as i really have spent so much time on my images, menus audio and basicly lost it all. If anyone knows a way round this pleeaaassseeee let me know
Thanks again -
Maybe you should create an image, transfer the image to your burining PC and burn the image there!But do only use ULEAD's burning program (if you want to play the result on a standalone player)
How do i create an image of the project when the Make disc icon isn't highlighted for selection. How else woulod i make a DVD image of the project?.
Nero 8 project, burn error... log file shown
By dvdking77 in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 10:51 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
DVD Workshop 2: Where is the best tutorial for this project?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2010, 10:09 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 13:49 -
Burn standard DVD project to Blu Ray disc?
By whoisquilty in forum Authoring (DVD)Replies: 12Last Post: 24th Feb 2008, 15:21
