How comes that, even when i set the bitrate tab as
Between 0 and 60 min. Use 1 CD size 800
Between 60 and 120 min. Use 2 CD size 800
Between 120 and 180 min. Use 3 CD size 800
Between 180 and 240 min. Use 4 CD size 800
i get files > 2 CD when the movielenght is <120 min ???
anyone knowes what i forgot in the settings??
i used this ini file :
:arrow:
Code:[Executables] PVA Executable= vStrip Executable=C:\DVD2SVCD\vStrip\vStrip.exe DVD2AVI Executable=C:\DVD2SVCD\DVD2AVI\DVD2AVI.exe BeSweet Executable=C:\DVD2SVCD\BeSweet\BeSweet.exe MadPlay Executable=C:\DVD2SVCD\MADPlay\madplay.exe MPEG51 Executable=C:\DVD2SVCD\MPEG5.1\pub_enc.exe CCE Executable= VFAPI Executable=C:\DVD2SVCD\VFAPI\Reader\VFAPIConv-EN.exe TMPGEnc Executable=C:\TMPGENC\TMPGEnc.exe Pulldown Executable=C:\DVD2SVCD\pulldown\pulldown.exe SubMux Executable=C:\DVD2SVCD\WinSubMux\WinSubMux.exe bbMPEG Executable=C:\DVD2SVCD\bbMPEG\RunbbMPEG.exe I-Author Executable= VCDImager Executable=C:\DVD2SVCD\VCDImager\VCDImager.exe VCDXBuild Executable=C:\DVD2SVCD\VCDImager\VCDXBuild.exe CDMage Executable= RunPerCDImage Executable= RunFinal Executable= MPG2Dec DLL=C:\DVD2SVCD\MPEG2Dec\mpeg2dec.dll InverseTelecine DLL=C:\DVD2SVCD\InverseTelecine\Donald Graft\decomb.dll Subtitle DLL=C:\DVD2SVCD\Avisynth Subtitler.dll BMP Loader DLL=C:\DVD2SVCD\Avisynth BMP Loader.dll Title Picture=C:\DVD2SVCD\DefaultTitlepicture.bmp Change CD Picture=C:\DVD2SVCD\DefaultChangeCD.bmp Last CD Picture=C:\DVD2SVCD\DefaultLastCD.bmp Dividee MPEG2Dec=C:\DVD2SVCD\MPEG2Dec\mpeg2dec.dll [Folders] PVA Folder=C:\DVD2SVCD\Movie DVD2AVI Folder=C:\DVD2SVCD\Movie vStrip Folder=C:\DVD2SVCD\Movie Audio Folder=C:\DVD2SVCD\Movie CCE Folder=C:\DVD2SVCD\Movie TMPGEnc Folder=C:\DVD2SVCD\Movie Pulldown Folder=C:\DVD2SVCD\Movie bbMPEG Folder=C:\DVD2SVCD\Movie I-Author Folder=C:\DVD2SVCD\Movie Subpictures Folder=C:\DVD2SVCD\Movie\subs [Settings] XPos=261 YPos=216 FirstRun=0 UsePVA2SVCD=0 UseDVD2SVCD=1 UseAVI2SVCD=0 UseMPEG1=0 UseMPEG2=1 Convert to Canopus codec=0 Convert to Divx4=0 Use Frameselection=0 New Default Folder=0 Anamorphic Aspect=1 DVD2SVCD Level=0 UseDVDRip=0 UsevStrip=0 UseInternalRip=1 Eject DVD=0 iDCT=0 DVD2AVI Pause=0 Luminance Gain=0 Luminance Offset=0 Audio1Downsampling=0 Audio2Downsampling=1 Audio1BitRate=9 Audio2BitRate=9 tooLame Mode=0 Autodetect Azid Gain=1 Folder Structure Source= Folder Structure Video= Folder Structure Audio= Folder Structure Muxed= Folder Structure Subs=Subs Intra=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34,37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,26,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83 NonIntra=16,17,18,19,20,21,22,23,17,18,19,20,21,22,23,24,18,19,20,21,22,23,24,25,19,20,21,22,23,24,26,27,20,21,22,23,25,26,27,28,21,22,23,24,26,27,28,30,22,23,24,26,27,28,30,31,23,24,25,27,28,30,31,33 Matrice Preset= Use deafult Matrice=1 LFEDownmixLR6Ch=-3 LFEDownmixLFE6Ch=0 CenterDownmix6Ch=0 SurroundDownmix6Ch=0 DynamicCompression6Ch=1 StereoDownmixType6Ch=0 RearChannelFiltering6Ch=0 DialogNorm6Ch=0 LFEDownmixLR2Ch=-3 LFEDownmixLFE2Ch=0 CenterDownmix2Ch=-1 SurroundDownmix2Ch=-1 DynamicCompression2Ch=1 StereoDownmixType2Ch=0 RearChannelFiltering2Ch=0 DialogNorm2Ch=0 No Audio Conversion=0 Flip Vertival=0 Add ResampleAudio=1 Resize To=0 Use CCE=0 Use TMPGEnc=1 CCE Safe Mode=0 NoOfpasses=4 CCE Image Quality=17 CCE Anti noise value=2 CCE Anti noise=0 CBR=0 One Pass VBR=0 Multi Pass VBR=1 RoBa Multi Pass=0 RoBa Visibel=0 CCE Bias=20 CCE Field Order=2 Progressive=1 Auto Intra DC=1 DVD Compliant=0 Restrict auto I frame insertion=0 Close all GOPs=0 Intra DC=2 M GOP=3 MN GOP=5 SEQ Header=1 Constrained Parameter Set=1 TMPGEnc Rate Control Mode=2 TMPGEnc Motion search precision=4 TMPGEnc Field Order=2 TMPGEnc Num of passes=2 Prediction Size=0.999 OffsetFixed CQ Value=80 OffsetFixed CQ_VBR Value=25 Use fixed CQ Value=0 DC component precision=0 Output YUV data as Basic YCbCr not CCIR601=0 Use floating point DCT=1 No motion search for still picture part by half pixel=1 Soften block noise=0 Soften Intra=35 Soften NonIntra=35 TMPGEnc GOP I Pictures=1 TMPGEnc GOP P Pictures=4 TMPGEnc GOP B Pictures=3 TMPGEnc SEQ Headers=1 TMPGEnc Max frames in GOP=0 TMPGEnc Close GOPs=0 TMPGEnc Detect Scene Change=1 Enabled Padding=0 TMPGEnc VBVBuffer=0 Dont Delete Files=1 Create VAF=1 QFactor=5 Linear quantizer scale=1 Zigzag scanning order=1 Use2Streams=0 Pri1Audio1=28 Pri1Audio2=-1 Pri2Audio1=-1 Pri2Audio2=-1 Sub1=80 Sub2=-1 Sub3=-1 Sub4=-1 Sub5=-1 Sub6=-1 Sub7=-1 Sub8=-1 Azid Gain Offset=6 SubOutputPalette0=clBlack SubBlendPalette0=0 SubOutputPalette1=clWhite SubBlendPalette1=15 SubOutputPalette2=$001E1E1E SubBlendPalette2=15 SubOutputPalette3=clGray SubBlendPalette3=15 Rip subtitles=1 Min. Delay. Between Subtitles=100 Resize Subtitles=100 SVCD subtitles=1 CVD subtitles=0 Permanent subtitles=0 PAL Y-Pos=-1 NTSC Y-Pos=-1 bbMPEG MPEG1=0 bbMPEG VCD=0 bbMPEG MPEG2=0 bbMPEG SVCD=1 bbMPEG DVD=0 bbMPEG VBR=1 bbMPEG Pad VCD=0 bbMPEG Write PEC=1 bbMPEG Add Scan Offsets=1 bbMPEG Align Sequence Headers=1 bbMPEG Use Private Stream 2=0 bbMPEG Computed Bitrate=1 bbMPEG TimeStamps=0 bbMPEG Pulldown=2 bbMPEG MuxRate=0 bbMPEG Pack Size=2324 bbMPEG Packets Pack=1 bbMPEG Video Buffer=230 bbMPEG Audio 1 Buffer=4 bbMPEG Audio 2 Buffer=4 bbMPEG videoDelay Adjustment=180 bbMPEG audioDelay Adjustment=180 bbMPEG audio1Delay Adjustment=180 Use MPEGAV=0 MinsHigh1=60 MinsHigh2=120 MinsHigh3=180 MinsHigh4=240 MinsHigh5=300 NumCd1=1 NumCd2=2 NumCd3=3 NumCd4=4 NumCd5=5 NumCd6=6 CDSize 1=800 CDSize 2=800 CDSize 3=800 CDSize 4=800 CDSize 5=800 CDSize 6=800 MaxBitrate=2530 MinBitrate=300 MaxAvg=2230 MinAvg=1600 Adjust Audio Bitrate=1 Use Min. Avg.=0 Force Film=0 Movie Offset=2 CDOverlap=2 UseCDOverlap=1 FixedChapters=0 DVDChapters=1 PBCType=0 Data Preparer=dvd2svcd Use I-Author=0 Use VCDImager=0 No images=0 Use VCDXBuild=1 Length of Chapters=60 Use TitlePicture=1 Use ChangeCD Picture=0 Use LastCD Picture=0 Use EntrySVD=0 Save XML=1 Save Movie Info=1 ProcessPriority=1 SmartDeinterlace Mode=2 SmartDeinterlace Treshold=10 SmartDeinterlace Denoise=1 SmartDeinterlace Blend=0 SmartDeinterlace Fast=1 Edit Avisynth Script file=0 Use CDMage=0 RunPerCDImage=0 RunPerCDImage Params= RunFinal=0 RunFinal Params= Automatic Shutdown=0 Avisynth Setup=BicubicResize [AVISYNTH_BicubicResize] 0=BicubicResize(^TargetWidth,^TargetHeight,^b_value,^c_value) 1=AddBorders(0,^BorderTop,0,^BorderBottom) ^b_value=0.0 ^c_value=0.6
you need to change to 1 cd then it will fit onto 1 cd instead of two, if the bitrate drops alot with 1 cd, then use 2cd the quality will be great
HI,
try to set 780 instead of 800 and/or reduce the averange bitrate by 50.
I have the same problem, when i split a file over 800 megs.
Bye. -
there is an option on this I think to set a safety margin (say 5%) or as above set cd size to slightly less than 800. remember a svcd CDR can hold more than 800Mb ?
The electronic components of the power part adopted a lot of Rubycons.
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
