I tried CD Stomper & Imation's Sonix CD labeler software and still is not satisfied w/ the design features of these products. Although Sonix is better than Stomper I still feel it's missing designs I like my cd covers to look. Sonix offers plenty of background designs but not enough editing tool.
Any suggestion welcome! Thanks,
Ames![]()
Results 1 to 9 of 9
Have you looked at the Sure Thing labeling program?
Hello. -
The one bundled with Nero I have found to be the best. I previously used Avery, which was OKay, but the results I get with Nero Cover Designer have been much better.
Cole -
They say I posted in the wrong area. I'll try to repost in the newbie area
Anyways, I think Sure Thing labeling is the makers of CD stompers.
Nero hardly seem to have any templates? Is this right? -
I used to use the memorex label program which was great but only works on their paper. With the stomper labels I have found the only usefull program is using a templete in adobe photoshop. Even with the templete though I still had to customize it to print perfectly. Hope this helps.
I was hoping to find a software that has the most template & designs so I don't have to create anything using photoshop (which I'm not that good at). Guess there is not such thing huh? Let me know if you find some
I like this software
DISCUS
it even allows you to decrease the inner diameter or outer diameter of your artwork!
http://www.magicmouse.com/_discus.html -
I have used fellows neato from a couple years now and am very happy with it. They have a template for just about anything you can imagine from cd's to minidiscs and vhs plus dvd case inserts which is what I am making the most of currently.
I checked out DISCUS and it looks exactly like Sonix. I guess Sonix just bought the design off of them.
Neato has 500 hundred backround images...very impressive. I'll ck them out some more ...thanks!!!
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
