I use InterVideo WinDVR 2.0 for capturing...and btw, it producess very good results even at hi-res!
The problem i notice today after hours and hours of test capturing and configuring...
The program was set to capture at 4300 Kbps. And the final mpeg file has reasonable size. For example, i captured today 1h 35min 16sec of video which came out as 3,11 GB mpeg.
BUT, when I loaded this file into TMPG for editing(i wanted to cut commercials out) edited file was about 11 GB!!!
I loaded original file again into TMPGenc to check bitrate of it...and it says 9799kbps!
Same happens when i load into any other editing program.
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 14:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 17:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 16:34 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 19:01 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 11:39
