I've searched the forums, and couldn't find any other listings that helped, so please forgive me if this has been answered before!
A little background:
I have a movie that spans 4 SVCDs. My DVD player will not support SVCD, so I burned them using the VCD header trick.
I was given a DVD burner for Christmas, and would like to now have all 4 discs on a single DVD. I checked out the link for fitting multiple VCDs and SVCDs on a single DVD (https://www.videohelp.com/vcddvdr and https://www.videohelp.com/svcddvdr) and began following the user guides.
The problem I'm having is demultiplexing the mpeg. I've extracted the mpeg from the dat on the vcd (remember, it was an svcd burned with the header trick) using vcdgear. The result was a 786 MB mpeg-2 file that plays perfectly.
Now, when I try to demultiplex the file using TMPGEnc, it gets about 60% complete on the video splitting, then skips to the audio. The two resulting files are a 500 MB m2v file and a 70 MB mp2 file. The mp2 file plays just fine, so the problem is obviously with the video file. A 500MB m2v is quite clearly too small for a video extracted from a 786 MB mpeg.
I've tried using MPEG-Corrector to fix any bad chunks, but the resulting file produces an "Illegal video stream" error in TMPGEnc.
If anyone could help with this, I would GREATLY appreciate it!! I'm getting very frustrated with this!![]()
Rock n' roll, baby
www.themindbloom.com -
Try using VCDGear to extract your DAT file directly from the VCD. Make sure that 'Fix MPEG Errors' is selected. I'm guessing you have a bit of corruption in your MPEG, or a bad sector on your disc.
Impossible to see the future is. The Dark Side clouds everything...
MKV Demuxing Problems
By Justin123 in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 02:33 -
Demuxing
By ckurowsk in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2008, 18:04 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 15:05 -
Demuxing Issue
By harshest in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2008, 17:14 -
what to do after demuxing?
By azizbhimani in forum SubtitleReplies: 2Last Post: 24th Feb 2008, 22:39
