    Aug 2001
    Australia
    I have to encode some videos from MPEG2 to VCD, and on two of those when I encode them, they get to a point where TMPGEnc closes with no error message or warning, it just disappears from the screen. I've tried using different settings to encode the videos, but they still crash at the same time.
    Please tell me what to do...
  2. hi, i had the samething, bud it always happends on the end....
    after a while i went craz......... and i delete the proggie
    then i reinstalled it again and it works no more breakdowns.
    perhaps it will work for you as well.
    goodluck
    Aug 2001
    Australia
    Well, I tried that as well, but no luck, it still crashes.
    Please help!!!
    Aug 2001
    Australia
    anyone???
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Did you scan and remove any bad frames first? If no, then there are guides for it.
    Aug 2001
    Australia
    I can't scan for bad frames in VirtualDub because the source file is MPEG2 and I don't think VDub supports MPEG2, is there aby other way to do it??
  7. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You can try Vcdgear for mpeg repair or have you tried the header trick? It means re-multiplexing the mpeg2 into an mpeg1 (with TMPGEnc) and burning it as a non-compliant VCD. Some players accept it, some don't. 8)
