day 1, freezes
day 2, freezes
day 3, "powerdvd does not supported this format"
day 4, finally make a good svcd. but CCE leaves it's stupid logo on my movie the WHOLE time.
can someone tell my how to get around this logo thing? (how dumb are they to put their logo in the middle of the screen?)
<font size=-1>[ This Message was edited by: nfl2k2 on 2001-09-06 19:20:00 ]</font>
How dumb of you not to know that its a TRIAL VERSION and that is something you should expect.
I think the reply was sort of like:
Q: "Hey, I can't believe how stupid some software guys are. Like M$ Excel, what's up with those grid lines everywhere?"
You have a demo copy of CCE, it's a very expensive program. I've heard rumors that there are cracks that will remove the logo/watermark.
Maybe someone more kind than I can point you towards one (see I'm only 1/2 a dick I tried to answer your question
I started using DVD2SVCD and like you, I had problems the first few times I did it.
I have since learned to DEFINATELY RESPECT the program when it says not to touch anything. It honestly means it.. do not TOUCH IT at all.
Since I started leaving it completley alone (thankfully I have a server machine just for this type of stuff) I have not had one single problem and the quality of the movies is fantastic!
As for the CCE problem, that is because you have a Trial Version. If you can find the full version of the program it will get rid of that problem of yours.
Go to the doom VCD forum @ http://www.doom9.org/ and check out their links, you might find a link to a spanish VCD site where u just might find what you are looking for.
Of course....u just might have to use a web translator to understand what the hell is going on...but if i remember u have to run CCE ver 2.5 with dvd2svcd and u might be able to download a English demo package (ie more than the setup proggy) from there.
If u get desparate PM me
<font size=-1>[ This Message was edited by: nsdn on 2001-09-06 22:12:52 ]</font>
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
